I used add a fuse and wired to fuse box, primarily because I added smart cord with mute button.
Bigzaj: Could you tell me which fuse panel and which fuse you used with your add a fuse? I just ordered my Uniden R3 with the smart cord and would like to install it just like you did. Thanks
R3 Mirror tap no issues. Just pull the power if you want to turn it off
Thanks, I'm in VA and radar detectors are illegal so I have to put mine higher up (above the mirror) and I thought a wire from the headliner would install better than coming from the mirror. Any thoughts on that?
---------- Post added at 01:55 PM ---------- Previous post was at 01:54 PM ----------
Also, how do you silence this when it goes off if you don't have a mute button hard wired?
Do you know which wire you used for the Ground and the hot?I used Mirror Tap with no problems.
