R starting issues...
Matmanand4
Eagle Mountain Lake, Texas
My 23 R just had 2 cycles where it had the long start. Has 12K miles on it. Never had the issue before. Also seems to have a miss now and not sure why. taking it to the dealer later this week.
Marcos Figueroa
Florida
I have 4,200 miles on my 24' and it has done the long crank up one time. I have noticed thought that sometimes it idles pretty high out of nowhere at times when starting.
Bfast
SD
I have a 24' R, and this morning it turns over but will not start. It says service vehicle soon, service charging system, service advance trac, and pre collision assist not available. 5,000 miles on it.
ToadSmasher2K1
Home Is Where You Make It
KC
It will probably start if you disconnect the battery for 10-20 minutes and let it reset. Might solve your problem until you can get it to a dealer tomorrow.
StuartR
Snohomish WA
My wife’s R had a bad starter button from the factory. Only start if you pushed the left side, nothing anywhere else. New button and all is well.
ToadSmasher2K1
KC
Probably not the issue, but make sure all the fuses are seated.
Bfast
SD
I unhooked the battery for a couple hours and tried it. Turns over but won’t start. Then after it fails to start it will not even turn over again unless I unhook the battery and hook it back up.
HAP
NE NC
How long does it sit between uses?
R,
HAP
bahama_man
texas
Hi everyone!
I’ve been having the same prolonged starting issue where it cranks and after a few seconds it starts a little rough… anyone know what’s the fix?!
Help please!
Thanks
