RAPTORSV
The Adam's gun has a 3/8" male quick connect, so you need a 3/8" female socket quick connect coupler for your hose.
The variable is what kind of threads are on your hose end. Many hoses are 3/8" NPT threads but they can also be 1/4" NPT or M22.
You can find these quick connects at Home Depot or Lowes which makes it easy to get the correct one by taking the gun and hose with you. Or if you know what threads are in your hose you can order one online.
Once you get the gun, you can also take the male quick connect off and if the threads are the same as your hose, just take the quick connect to the store to match it up.
https://adamspolishes.com/shop/specials/foam/adam-s-foam-cannon-snub-nose-combo.html
Sent from my SM-N950U using Tapatalk
---------- Post added at 12:22 PM ---------- Previous post was at 12:20 PM ----------
Here's an example of a female coupler with 3/8" NPT threads.
Forney 75129 Pressure Washer Accessories, Quick Coupler Female Socket, 3/8-Inch Female NPT, 4,200 PSI https://www.amazon.com/dp/B003X5PR8Y/?tag=fordraptorforum-20
This is the typical replacement hose. I had to replace mine awhile back because it got cut. Bought from Lowe's, they were all the same. What I can't find is the male end to connect to this to convert to the 3/8" female quick coupler. I have no way to connect to the coupler you linked to on Amazon.
