Rogue Racing
- Joined
- Feb 5, 2014
- Posts
- 570
- Reaction score
- 652
ATTENTION 2017+ Ford Raptor owners!
Rogue Racing has placed a stocking order for OEM Replacement King Shocks IBP 3.0 coilovers and 3.0 piggyback, 4 tube bypass shocks. Current lead time is 8 weeks, so place your order now to get a set for your ride. Call 702-586-6483 or email [email protected] to order!
2017+ Ford Raptor
King Shocks 3.0 IBP Performance Series Kit
100% bolt on
Large 3.0” OD shock bodies
A true, full diameter piston and valve stack for maximum damping control
Fully able to rebuild, service, or tune
Finned Reservoir
Factory tuned for optimal ride quality
Material quality and tolerances to match our top race shocks.
Front
Large 3.0 mono-tube shock body
Patented “Internal Bypass” (IBP) technology
Compression adjuster
Reduces shock cavitation
30 clicks of compression adjustment
1” diameter shaft
3.5” OD finned reservoir
1 piece extrusion- not a sleeve
New hose attachment allows easy hose clocking
100 % bolt on
$3499.99 MSRP
Rear
Proven external bypass design
4 Bypass tubes
Position sensitive damping
Separate compression and rebound external adjustments
1” diameter shaft
2.95” OD finned reservoir
100 % bolt on
$2899.99 MSRP
2017+ Ford Raptor
100% bolt on
Finned Reservoir
Front
1” diameter shaft
100 % bolt on
$3499.99 MSRP
Rear
4 Bypass tubes
1” diameter shaft
100 % bolt on
$2899.99 MSRP
