MTM foam cannons are made for gas high pressure washers FYI. Won't work right with electric.
Not true. It works with any pressure washer between
1100-5000 psi and 1.8-5.3 gpm.
https://www.amazon.com/dp/B004GNZYY4/?tag=fordraptorforum-20
The even sell one withe a Karcher bayonett fitting.
http://https://www.amazon.com/MTM-Hydro-Professional-Adjustable-Bayonet/dp/B00EDSLVQC
I have used mine with a Karcher K3 and a K5. Works great.
Just to clarify, I had told Azholly that of the two that we sell, the
Adam's Red Foam Cannon is better suited to budget-level electric pressure washers, and the
MTM Foam Cannon works a little better with the more powerful gas pressure washers.
That's not to say the MTM won't work with an electric PW, just that you might find that you get a little thicker foam with the Adam's model on a electric PW. Note that this does vary a little between different brands of pressure washers, and on the ratings on the electric PW (budget-level vs pro-level), and also varies with how much
shampoo is used in the cannon.
It is important to note that MTM actually makes two different versions of that particular cannon. The one geared towards the budget-level electrics has a smaller orifice (1.1mm, model #14.0349), and then the version that crash457 linked, which has a larger orifice (1.25mm, model #14.0263), works better with gas pressure washers.
My pressure washer is the AR Blue Clean AR630-TSS-HOT, which is a pro-level electric, and I do get thicker foam with the
Adam's Red Foam Cannon than the
MTM Foam Cannon model that has the larger orifice (#14.0263).
