Power washer??
Kowboy17
in an FBI van
I have the Greenworks one you described. Works fine for foam cannon, drive way cleaning etc. good little power-washer that is easy to move, put away and use. Has all the nozzles with it and works fine. Going on 2 years with no issues.
matt33
NE PA
I have had a Honda GC160 with the 5.0 pressure washer for at least 15 years. 2 or 3 pull strings replaced, the carb being cleaned a few times and the wheel fell of once. Starts with ease and run great all the time.
I have one with the same engine. It has been a workhorse for at least 15 years.
Azholley
17 AG, 21 IS, R pending
Peoria, Arizona
Not true. It works with any pressure washer between
1100-5000 psi and 1.8-5.3 gpm.
https://www.amazon.com/dp/B004GNZYY4/?tag=fordraptorforum-20
The even sell one withe a Karcher bayonett fitting.
http://https://www.amazon.com/MTM-Hydro-Professional-Adjustable-Bayonet/dp/B00EDSLVQC
I have used mine with a Karcher K3 and a K5. Works great.
I'm just going off what Adams told me. They said it'd work but not as well. Good to know tho
Dachuri
Memphis & Austin
Need help deciding what power washer to get. Looking at Greenworks 2,000-PSI 1.2-GPM Cold Water Electric Pressure Washer or Sun Joe 2000-PSI 1.76-GPM Cold Water Electric Pressure Washer. I'm going to be using it to use the mtm foam cannon.
I've got the Greenworks 2,200 PSI. Works great on stone fences, driveways and my Adam's foam cannon. It's not big either so it fits in the garage nice. You can buy a Lowe's $50 off coupon on EBay for $2 and use it on an online purchase and have it shipped for free.
I went with the 2 year no questions asked warranty from Lowe's for like $40 too. Basically if you think it's not working properly at any point in 2 years, bring it back and get a new one.
J
jeremyespinoza
What are those going for?
---------- Post added at 09:25 PM ---------- Previous post was at 09:24 PM ----------
Great thanks for the info
---------- Post added at 09:26 PM ---------- Previous post was at 09:25 PM ----------
Thanks for the heads up buying a foam cannon right now
kdkellie
I use foam cannons with electric power washer daily. Works perfect. I'm not a fan of gas machines they're annoying running them constantly. I've even used check electric pw with foam canons with zero issues. I know have a commercial electric machine.
Sent from my BBA100-1 using Tapatalk
