Post Your Wheel and Tire Pics !
The Macf
Vegas
The Macf
Vegas
Most likely. Will see how the stock method center caps look once i get my black lugnuts in.
TargetBow
How much air do you have in them? They look over inflated probably an optical illusion
I have the tire pressure at 43 psi front and back I'm not sure what pressure everyone else is running in their duratacs.
---------- Post added at 06:51 PM ---------- Previous post was at 06:47 PM ----------
TargetBow,
I just got the same tires for mine...you on mid-perch?
Looks good. buddy.
Thanks, I'm on the stock shock setting
Wilson
South Dakota
I don't remember but it's on the door. That what I run anyhow. I know some run less some more.
Stang
47 front / 45 rear for me and they feel better than stock in every way.
TargetBow
My door sticker says to run 44 psi in both the front and rear with stock tires. I did that for the life of the stock tires which I rotated every 3,000 miles not 5,000 and at the end of their tread life, which was 49,000 miles. I see that the center of the tread has worn a little more than the outside of the tread, so I think running the OEM recommended pressure all that time, I may have been running the stock tires over inflated. I really don't want to run to much pressure in the new duratracs so I started at 43 psi and when I get a chance I will try the chalk test that I read about.
Any thoughts on why the stock tires wore the center of the tread more than the outside? Is the OEM recommended pressure incorrect?
Thanks: Ed
Wilson
South Dakota
The back is lighter than the front and if your spinning tires I can see why the center went faster. I like the idea of running a psi or two less in the back. You can't help to spin the tires a bit on these trucks. If I get over 40k I'm good. I'm not an expert on tire psi
SuperRaptor
Seattle
Thanks: Ed
I've worn out a few pairs of BFG A/Ts and they always seem to wear the middle out first no matter what vehicle/psi I've ran them on. They also seem to grip very well down to the last few 32nd's.
