Post Your Wheel and Tire Pics !
rpp_85_
offset
Thanks, here you go:
image by tony911tt, on Flickr
Hello, Im new here, i Have 2013 stock raptor, and im deciding between 20x9 with +1 offset and 20x10 -12 offset Fuel mavericks with 295 60 20 nitto terra... can you help me decide and make up my mind? the only reason i havent chosen the 20x10"s is because everybody says that if I go that way, probably I will have to use a level kit, I dont want that, i just want to go mid perch like you did. Is it possible to have 0 rubbing with that setup?
Thanks
ljn21
Tega Cay, SC
Fuel Trophy's in 18x9 +20mm offset in Anthracite with black beauty rings. Toyo Open Country MT's in 315/70/18.
Nick@Apollo-Optics
Pro Comp Series 35 (5035) Predator wheels installed. 17x8.5 and 0 offset. Hub centric at 87.1mm. Perfect fit. Easy to balance. No wobble on the freeway. Running them on the stock BFGs for now until I upgrade tires at a later date. Weight is 35lbs which is just 4lbs more than stock. I'm very pleased with how they turned out.
TonyNJ
North Jersey
Thanks
I had very minimal rubbing with the 20X10 wheels. I had a mid perch setting and would only rub at full lock and on a certain angle. Not bad at all.
