He posted some updated photos of the amp rack on F150 forums. There is no doubt that he is a very gifted installer.
The shop is almost 8 hours away. Unfortunately the city I live in, didn't have a shop I trusted. They are working with me to try to figure it out. They are shipping me some new cables that should fit onto my amp rack and move the power on the zen and the DM.
That said, I just had some really strange stuff happen. I took a jumper cable out to the truck and ran it to the negative terminal on the battery to do some resistance testing between the battery and the hardware. First of all, does anyone know what the black thing on the negative battery terminal is. I've attached two pictures of my negative terminal. Now here's where it gets nuts. If I disconnect the negative 1/0 cables from the battery, I get 0 ohms of resistance between the terminal at the battery (disconnected) and the negative allen screw on the amps. If I reconnect the 1/0 cables to the battery I get anywhere between 5ohms and 11 ohms. This is true of both the ground run to the frame and the ground run to the factory ground. Why would connecting it to the battery make my negatives go to 5-11ohms of resistance?
I’ll have a whole album detailing my install in about a month. But here are a couple sneak peeks. (I did not fabricate the a-pillars) Still fabricating other pieces, waiting on more sound deadening and one more amp! Still have a long road ahead. Haven’t even begun running wires.
Some of the components:
3 x SI MK V 12" subs
Morel Mids and highs- 3 way active front stage
3 x AudioControl amps
Helix DSP Pro MK2
Helix Director
Custom 1/4" ABS amp rack
Custom 5/8" MDF box
SMD digital fuse block and ground block
NAVTV Zen a2b to tie it all together
It's gonna be fun!
Thats an incredible system. Im looking forward to seeing the whole install album. Curious to see your sub box build pics.
Very nice fab work on the mid/tweeter pods too. Did you do the fab work?
Question, isnt 3 SI MK V's a bit of overkill?
