So good bro! What did you dampen with on the back wall?
I will try to get some install pictures up from my truck in the next few days. It came out pretty nice, but I am tracking down a ground problem right now.
I do not need to run a 1/0 ground all the way from the battery. Steel is steel and a frame ground will work fine. Also, the fact that when you remove the DM 608, your hissing stops and audio doesn’t cut out, tells me the problem is with the AudioControl dsp. How are you powering the dsp? And from what power source?
Also, when was the last time you updated your NavTV unit?
I didn't do this install myself. I debated back and forth on it, and finally decided to have a reputable shop do it. The shop that did the install updated the NAVTV. I have not traced where the DM-608 is powered from or grounded to yet. The NAVTV is grounded to the same place as the amps though. He had it grounded to the harness, but we got some alternator whine from that, so he moved it to the amp ground. The install is super clean and everything is very tucked away. Unfortunately, while that makes everything look really nice, it also makes it hard to trace things down, and I have been pretty busy as of late.
I think part of the issue is the way the NavTV is powered. While you had alternator whine, I doubt the shop tried to also check the power source of the dsp. Navtv specifically states in the installation instructions what power and ground wire to tap into. Also, the AudioControl dsp should ideally be hooked up to the same power source as the NavTV unit. It does not pull hardly any amperage and the power wiring from the b&o harness is more than capable of handling both loads.
Lastly, you need to make sure that the remote wire from the NavTV unit is being used for the dsp and amp. If these units are using different remote sources, that could cause interference and potential loss of audio.
---------- Post added at 09:53 AM ---------- Previous post was at 09:49 AM ----------
How long ago did you do the install? Because there was updates released within the last 15-20 days or so.
