Phoenix Android Audio retains Sync 3
djc1603
Cypress Tx
I was sent the link to the file that resets the configuration for my vehicle, in addition to the simplecan update to address the no sound with streaming sources issue. After installing it a couple of times it worked and I haven't experienced the no sound issue since. However, since updating, the volume for Spotify, Tidal, etc. (All streaming sources) has been greatly reduced. I have to turn the volume all the way to 30 to get any decent output. And if I forget and switch to console mode it blows me out of the truck. I have tried adjusting the gain levels in the settings menu but they have no effect. I was having an issue of distorted sound from streaming sources that I reported to them and they aknowledged it as a known issue that they were working on. I'm wondering if the updates I applied reduced the gain to reduce the distortion issue? Has anyone else experienced this?
ROBERT F HAVENS
Fort Bragg, NC
You may need to change the fader to the opposite of whatever it is set to in the settings of the device not Sync3. That happened to me too. Turn volume down before changing it.
Sent from my SM-N960U1 using Tapatalk
BIGDJE
OC, CALI
i assume line level was turned way down by update. i am having same issues with tidal using app on tablet sounds like speakers are capping out looks like there was a update but now its to low
odd turning up line level does nothing. i just sent them a text on this. i will post their response once they reply back to me
djc1603
Cypress Tx
Thanks for checking. I left them a voicemail on Friday about it as well. Also, see if you notice a high noise floor (hiss) when playing songs. When I advance to a new song in Tidal, there is no sound but as soon as the music starts, I hear a slight bit annoying hiss. I hope this may go away if they correct the gain levels.
Since you are a Tidal user, have you noticed the very bottom of the Tidal interface is covered by the lower Phoenilx control panel (AC and volume control panel)? More annoying, do you have the issue of when you hit the play button, it brings up the Tidal streaming options screen? I assume this is a Tidal issue.
nah_tan
Well this has been fun. I did the Software update and did t fix the sync 3 flickering screen. I then did the simplecan update and still didn’t fix it so I hit the reset button with paper clip and now the unit won’t even power up just black screen.....
This is exactly what happened to me after simplecan update. I have a new unit coming to me but now I'm afraid to update simplecan.
Mcdonaho
Richmond, TX
I emailed them for refund or replacement. I want a replacement just waiting for them to email me back....
nah_tan
Would anybody be willing to make a video doing the simplecan update on our units? I know there is a video from phoenix out there but the menus are just a bit different and Id like to see how people are getting their USB to be recognized. Do you exit back to the unit or save and reboot when finished?
Mcdonaho
Richmond, TX
I had to put usb in and hit reset and when it came back up it recognized the px3 auto update and did that then reset unit again and did simple can update. Then reset it again and black screen...
Raptor18Actual
I just got mine installed over the weekend...everything seems to be working alright
  1. I'm scared to do the updates because of these last few posts
  2. What's everyone doing for hotspot? I don't have an unlimited data plan and was thinking of getting a mobile wifi hotspot vs OBD hotspot so I could use it away from the truck as well
