Phoenix Android Audio retains Sync 3
BIGDJE
OC, CALI
I haven’t gotten so far as to screen mirror yet but I’m sure it’ll work as advertised. Everything works perfectly with sync, the stock functions, the stock nav. Etc. Then you have this whole platform built around that which is nearly perfect...
And most import... it looks like 2019! Not 2006!
i did screen mirror using tablet screen and my android phone works great using app called EasyCon
BIGDJE
OC, CALI
Little update. Phoenix is sending me this today which then will display all kinds of stuff onto the screen using OBD wifi. Dont get blue tooth version has to be wifi one.
https://www.phoenixautomotiveinc.co...apter-auto-scanner-torque?variant=36605386701
Display current sensor data, including: Engine RPM; Calculated Load Value; Coolant Temperature; Fuel System Status; Vehicle Speed; Short Term Fuel Trim; Long Term Fuel Trim; Intake Manifold Pressure; Timing Advance; Intake Air Temperature; Air Flow Rate; Absolute Throttle Position; Oxygen sensor voltages/associated short term fuel trims; Fuel System status; Fuel Pressure; Many others...
G
Guy
Any WiFi obd2 will work With the torque app.
Downside is that you can’t connect to more than one WiFi at a time. So it’s of limited utility. You can’t be streaming data or phone mirroring and connected to that as well.
You’ll connect to it one time for 3 minutes and get bored and never do it again.
BIGDJE
OC, CALI
yeah i know just thought i get it and post it for those that wanted to see it.
i have a really nice blue tooth obd i use for Forscan but they said only wifi version will work with android tablet screen
i had to get a 3 dongle obd as it is for my amp steps, head up display, and owl camera so i dont need a 4th for sure
nikhsub1
Los Angeles
And bonus!
The DACS in the Phoenix unit must be higher quality than the stock ford stuff. The audio improvement is palpable when streaming thru the unit itself. My phone connected via blue tooth has more fidelity than connected via wire and apple play thru the sync. I’m eager to get some tidal streaming directly on it via WiFi.
It’s seamless the way you can switch apps, go to factory sync when you want it... etc.
So the quality doesn't get better if you use carplay then? Only while streaming?
BIG TIME BALLER
Virginia
Lets see some pics Guy!
