PDP Contour Fox Logo Mud Flaps Installed! Pics!
Boricuaevo8
Las Vegas!
Thanks!
I'll be heading out to Vegas in early May... you'll have to show me some spots out there!
Absolutely man, we have a good crew out here. I have buddy here @Bilwil that him and try to get some runs going. As far as that goes, he's the route guru here in Vegas. Hit us up when you're in town.
Jimbo
Mad Frog Mattis
IL
Sounds good. We will be there sometime May 8th-13th or 14th, whenever we decide to start our trek back.
Rookie
Fort Wayne, IN
they don't stop stuff from spraying back, they stop stuff from spraying up onto your side body panels. I've kicked rocks that have broken peoples windshields even with my PDP flaps installed, but I keep the rock chips off my paint! :D
and just to update, I installed my PDP flaps with factory wheels/tires in the OP. I've since gone Methods with 0mm offset which pushes each side out a bit more, I was worried at first my mudflaps wouldn't protect as much, but they still do a perfect job. Haven't noticed any difference at all from the increased track width as far as getting stuff flung on the paint.
I did the same thing. Although my fronts disappeared into the abyss. Only thing I want to do now is move my rears out some more as the 0 offset makes them not line up with the tire and it bugs me.
freedommotorsports.us
Phone: 260-444-7503
Email: [email protected]
dhollist
SE Michigan
Not the PDPs, but here's mine. These things have done miracles for eliminating the splash on my rocker and door panels (even though the truck is still dirty).
Are those Borla exhaust tips on an otherwise stock system, or did you get a Borla cat back system?
All the best,
Dave
1fastdoc
Either my flaps or my Raptor must be different than everyone elses.
On the rear, getting the top bolt drilled 1/2" from the top border of the flap, it still leaves a little over 13" of clearance. To get down to 12" and fully protect my exhaust tips would require a new hole below the factory location.
On the fronts I'm not sure cutting out 3.25" will be sufficient. I'm about to do that part now. I'm still bugged about the rear flap height and why it seems to be different than everyone else.
Edit: cut 3.5" down and also took it farther over to the side to prevent a big gap that would collect crap. That gets it to sit flush with 12" of ground clearance.
I still don't understand how OP was able to use the top bolt and get the flap down far enough that it was 12" from the ground.
dhollist
SE Michigan
35 profile tires? Lol
All the best,
Dave
FP Forged
Justin
Reno, NV
Figured I'd bump an old thread instead of creating a new one.
Has anybody mounted the fronts with a toggle bolt or a molly bolt. I just ordered a set and I know most people have been using self tapping bolts/screws but I couldn't help but think a toggle or molly with a little blue lock tight would be a more secure option. I could missing something though. What are your thoughts? Pics below for reference
Deleted member 12951
Guest
I suppose you could but I didn't see the other end of the screw from under the truck except for one
FP Forged
Justin
Reno, NV
Out of curiosity, what would seeing the other side of the screw have to do installing one of these style bolt/nut combos? These go in from the front and self anchor opposed to the self tapping screw anchoring to the plastic...
Guest
Meaning I didn't take apart the fender to see behind it. It is not exposed but suppose you could remove the lining to access it. What's the objective to ensure the screws hold? The self tapers have been holding great.
