We TIG weld our bumpers because it looks nicer then MIG welds.
Chromoly vs. Mild DOM (drawn over mandrel) all of our bumpers are DOM mild steel.
Chromoly is stronger then DOM mild steel so you can use a thinner wall piece of tube. .90 wall Chromoly is about the same strength as .120 wall DOM mild steel. , but half the weight.
Chromoly also has different bending characteristics and failure characteristics which is why its required for most roll cages.
For most of the customers Mild steel is the best choice because chromoly is not making you bumper much stronger its only cutting weight.
Chromoly can also be MIG welded. TIG is just our preference because we want the bumper to look very finished. It makes you wonder how I can TIG weld a bumper and use thicker materials and still be 200-300$ less then our competitors.
AII- you are way off one your pricing I dont know where your getting your Chromoly but your over paying.
Hope this helps some people out.
---------- Post added at 01:44 PM ---------- Previous post was at 01:32 PM ----------
DOM mild vs Mild steel
Sorry left this out.
Both DOM and Mild steel tube are electrically welded on a seem the runs down the length of the tube. You always want that seem to face up or down in a bend so that non of the stress from the bend is put right on the seem.
DOM however as an extra step after being welded it is drawn down a mandrel to get a much more uniform thickness throughout the tube. If its not DOM you tend to get weird ripples in the pipe and its hard to bend as consistently as DOM because the spring back amount tends to change throughout the pipe making it hard to be accurate with bends.
Spring back an rotation is one of the biggest facters in bending. If you do select the proper amount of spring back past the actual degree you want to bend it wont ever come out right. Chromoly, DOM< Mild Steel, Stainless steel all have different spring back. Things as small as temp and humidity can change spring back.
Rotation is very important as well. If you trying to make to bends for lets say the main hoop on a bumper and you dont have the tube perpendicular to the bend die and parallel to the floor you 2 bends will be off.
Thats the benefit in using a CNC bender you can save all yuor spring back settings and it makes the rotation right every time so you have consistent part everytime.
