OK I've been noticing before when I go up to the mountains that I would see it running hotter and even sometimes the over heat light popped on and once I let off the gas it would lower on its own pretty quick and I'd smell coolant so upon checking it each time it looks like it sprays coolant from the coolant tank cap on top from pressure or idk. But today I was going and its 32 degrees through the pass it was dry so I just went wot passing some cars then shortly after damn light comes on! And this time ***** hot 260f I pulled over popped the hood and was steaming like a chimney from coolant all over the damn motor. I waited a bit started again it starts to climb again on idle to 230 so I let it sit some more reflashed my tune, added some cold water that I had to make it to the gas station which wasn't far away thankfully, got a gallon of coolant and it nearly took it all, shocked how much it sprayed out, the cap seems to be loose though not sure if they all feel like that and again it seems likes it's spraying from the cap since it's wet from there and down. I see people do radiator changes and thermostat changes but still seem to run into overheating time to time. When not in elevation it usually doesn't go past 230 on the hardest driving. Any one else experience this? After putting the coolant and reflashed the tune I just drove it normally at speed limit and it didn't heat up any more the rest of the trip.
