bstoner59
does it come in shmedium?
There are a couple things you can't have too much of and lighting is one of those
Alrighty, got some more pics tonight after the game. Hopefully this will show exactly the pattern of the lights, as well as the distance. I currently have the lights aimed, roughly, straightforward.
As before, I took several pics trying to replicate what the eyes see. The one difference between these and the garage pics, was the color hue. All the pics weren't able to pick up on the subtle blue the lights shine. That being said, the brightness levels, are as accurate as I could get them.
First set are measured out shots taken from beside the truck. The cone is at 100' and the 6' fence, as well as my dad, are at 180'.
Headlights low beam:
HIDX only:
Zoom of HIDX only to show light height in trees:
The next 4 we took just to show objects in the beam.. and so I could blind my dad some more.
Low beam:
HIDX only:
High beam:
HIDX only... that fence behind the furthest tree trunk is just over 200' away
Now for some distance shots. The orchards edge is approximately 200' from the bumper and the trees are spaced about 15-20 apart.
low beam:
High beam:
HIDX and low beam:
Those last two shots really tell the story for me. These lights may not throw any further than the high beams, but they definitely throw more light for that same distance over a wider area.
Now, picking out objects at 200-300 feet may not be enough for some of the shenanigans this truck can get you into. But just imagine these paired with a nice long range set in the center of the bumper, or even roof mounted. Then you've got yourself some very capable lighting!
I'm putting mine on later this week with the 4" Hella OptiLux HID's. I have the VisionX 4500 HID's but when you compare them side by side it just doesn't make any sense to spend nearly $300 more on the VisionX lights for as little as I will use them.
A big thanks to BigJ and Puddle Jumper for providing these write ups to help guide me through the install process, I'm sure they will be a huge help. I'll post pics when it's done.
Tejas
Tejas
Tejas
Puddle Jumper... I like that.. makes me sound all, world traveler like!
Good luck Tejas, you're gonna love this mount location! I was going to use the Optilux, but they looked identical to the HIDX and I decided to support a site vendor!
These lights look alot like the HIDX and the Kragen.
