iSurvive
OK shooterAMG, it sounds like you need my extended tips and tricks. I have the VisionX HIDs and they presented the issues you mention.
First of all the holes in the hood mounts are too small for my HID bolts, so I had to use a drill to expand the holes. The bolts are also very long, so I had to drill holes in the cowl directly below the holes in the mount (using a long drill bit and drilling thru the mount hole and into the cowl below). Then comes the washer and nut...
There is only room for the nut and washer period. I used Scotch tape to tape the washer and nut together (just a small piece). Then I use a long thin wrench to push the nut in place and hold it there. It is VERY helpful to have another person hold that wrench in place while you install the light.
Since the area is so tight, with no room to move the wrench, you must rotate the light to screw it down into the washer and nut. This is very difficult because the lock washer is hard to thread. It takes 20-30 full turns of the light to get the nut all the way on. Keep turning the light until the nut is very tight - you may have to slightly move the wrench to get the lights straight while keeping the nut tight.
Honestly I had no idea how people were doing this install. The nut, bolt, washer issue seemed impossible. I did it by myself on the first install, and it took me almost 20 minutes to screw in one light. Then I got my son to help by holding the wrench and keeping the nut in place. I was able to use two hands to screw in the light and keep it straight while turning. Ten times easier!!
You can also add extra washers between the truck frame and the brackets - this raises the brackets higher and gives you more room for the nut. It also raises the lights higher, which some people like since it can reduce the glare on your hood.
Good luck! It may require enough beer to keep you calm, but not enough to impair your skills.
In case I read your post wrong - maybe you are asking about the back bolt on the bracket. I did cut the cowl a little more so I could reach the back bolt with a long extension on my ratchet set. I see no other way to tighten the rear bolt. But I did cut the minimum amount of cowl possible to keep it looking clean and professional.
