Old Man Build
XSTNKT
Michigan
In the wheels won't add a ton of cost to the whole project, considering I was planning on getting bead lock rings (800 for a set of 4) and another spare (400-600 the way the oem wheels are priced and yes all 6 have to match). I can get 6 of the Icons for $1800.
Have you considered Volk (Rays)? I believe they are lighter. I believe the TE37 is available in our lug patter in a 17", either +16 or +20 offset.
Nevermind.... they are only in 18". Bummer.
O
Old-Raptor-guy
USA
Fifteen52 is having a sale, they have some neat wheels
Since I air way down, 18ish psi normally (would go lower in the sand but don't dare without something holding the bead) I want something that is or acts like a bead-lock. ICON has the innerlock and method has the bead grip. All the methods look to be 0 offset.
I thought Method added a +25 bead grip???
Nex
RIP CoronaRaptor
Washington State
What does the RPG UCA require for offset? Most require a zero offset.
I have zero offset Methods and still had to run the small spacer from Alcon to clear the calipers.
O
Old-Raptor-guy
USA
says works with stock wheels and tires. "Working" is a little ambiguous i guess, says fully adjustable on the truck also and that is a load of horse shit.
DAVfoto
Clifton NJ
Only UCAs that I know of that work with stock wheels seem to be Camburg and Icon, and the Icon's are adjustable on truck but none of the rest are.
DAVfoto
Clifton NJ
I'd like to note, 18 PSI on stock raptor wheels, or wheels without bead grip is nothing.. You can air down to 12-15 stock, it's when you get lower than that, the issues of blowing the bead arise. Beadgrip wheels can go down to like 8-10 no issues, beadlock, run it at 4-8 and be fine.
It all depends on driving characteristics, bombing through the desert? I wouldn't go lower than 24 to be honest.
O
Old-Raptor-guy
USA
Understood, I wouldn't go lower unless traction requirements were necessary.
I would 110% admit that 18 seems to low, but the ride quality over cobble/wash board roads is so much better the lower you go.
Before the Raptor I would take my F350 down to 25ish psi.
Obviously road conditions vary.
DAVfoto
Clifton NJ
Yea, it definitely helps ride quality. I rode around in 23-24 psi in Moab and didn't feel that bad ride wise. Went down to 15 ish for Assateague Island on the beach.
