Old Man Build
Nex
RIP CoronaRaptor
Washington State
Spot hitting is about a 1/4 inch closer to center of wheel than Method wheel.
Might, I repeat MIGHT be able to machine a little off the caliper. But that could be scary and expensive mistake.
I tried that as well. But doesn't look like I took a picture. Something about grinding in brake calipers makes my hair stand up. Still had to run a spacer.
O
Old-Raptor-guy
USA
Yea, small spacer for now. Not ideal. I learned alot about how wheels are made, so not a loss at all.
O
Old-Raptor-guy
USA
So, clears with the 6mm?
I need to get spacer, but can not imagine either wheel would not clear with 6mm. Both were with lugnuts finger tight but the wheel was fully seated on the hub/rotor.
It rubs the paint, but with about 20 lbs force you can move the wheel so it isn't like it is locked up solid. I will report back ASAP.
Tomorrow is install "chase rack".
BlueRecaro19
NJ
I'm a little late to the party, but am looking to install E-Clik soon on my Gen 2. I only briefly watched their Gen 3 video, but I wonder if you can mount their ECU under the driver seat instead of the engine bay for an easier install on a Gen 2. The wire lengths are probably different, but just something I was thinking about. Maybe a call to SDI would be a good idea.
XSTNKT
Michigan
Meh, just do a couple hole-shots up and down the street. They'll make room for themselves. :buffer:
O
Old-Raptor-guy
USA
The install instructions are on Gen 2, video posted as reference from SDI is a Gen 2. I believe the install could be 100% done inside the cab on a 2019-20 with factory live valve. But would take some engineering liberties.
