Oil temperatures
xlr8
Tejas
That coolant temp must be wrong. Or a blend of coolant and oil temp like bmw does. 237 is head warping on most vehicles. And why is the gauge not at the top of the range?
New Nick at JDM
New Jersey
It all depends oil brand and type but 275 is when I begin to worry on my race car. 250 is perfectly fine and burns off contaminates.
This sounds spot on to me.
If you dig on the internet, a Ford engineer commented on proper oil temps in a Q and A session when the 13-14 GT500 came out.
Too cold can be a problem, if I recall Ford targeted 225-230 on the GT500's running 5w-50
I am guessing in extreme conditions the oil to water coolers can saturate the engine cooling loop to the point of being overwhelmed kinda like the Boss 302 Laguna Seca's did out of the box at track days.
xlr8
Tejas
You can go down a real rabbit hole as far as oil is concerned and how it's made, actual base stock ingredients. One of my friends used to be the CEO of Redline oil and boy does it get complicated. Basically just buy the best oil you can at the proper viscosity for the engine taking into account climate and change more often than the manufacturer recommends.
Frankly for a street driven vehicle the brand isn't as important as other factors. However if you routinely seem temps in the 270s or higher then yeah buy the best oil you can. It all begins to break down over 300.
YMMV
goblues38
STL
After a little spirited driving through some twisty off-road fun, I was seeing mid-260’s. Coolant temp hitting 250 as well. Upgraded to a Full-Race radiator and trans cooler. Have a aux oil cooler I just need to make a mounting solution for.
But low 200’s seems to be the everyday norm on the road.
That screen is the only thing i miss in my 18 vs a 19
Swarfworks
Michigan
yeah I agree. My ‘17 seemed to run hotter than my ‘19 on the road. But only saw these high temps pushing it hard at the dunes and the salt flats.
Oh, and when the coolant temp hits about 250, you get this fancy message (I had slowed to let it cool by the time I got the picture taken).
Trick.Raptor
The Cracker Raptor
Santa Maria, CA
I like that information display! Far better than what we get with the Gen1! What's below the inlet temp?
Brett Rahn
Brett Rahn
Pennsylvania
Oil was full when tsb was done it was ford synthetic oil and had about 300 miles on it. So oil was full not low
Brett Rahn
Brett Rahn
Pennsylvania
38E78F11-1217-40DF-8AE9-7044D39E7C05.png Tsb Get it done. Mine wasn’t burning oil per day truck only has 1200 miles on it. But after it was hot and sat 30 minutes or so it would smoke like hell on start up. So far so good. I was told it changes crank case venting and oil routing through valve covers
Bajabro
Sherman Oaks, Calif.
Just recently came back from chasing the Silver State 300. I had my Gauge View display for most of the trip and I noticed a few things that alarmed me a bit.
215-230 degrees
  • 75 MPH
  • A/C at mid level
  • Three total passengers
  • bed loaded (approx. 500 pounds)
  • 37-inch X-A/T Yokohama tires.
  • Outside temperature was around 95-100 degrees
  • Driving through flat and progressive incline highway grades.
240-260 degrees
  • 75 MPH
  • A/C at mid level
  • Bed loaded (approx. 500 pounds)
  • Driving through higher than normal incline highway grades.
Only mods:
  • 37-inch Tires
  • CAI by AFE Power
Please chime in if these are concerning temperature readings.
Kmorgs
Florida
I only have 3,500 miles, Stage 2 Cobb and running full ester based synthetic. Around town 195, highway in 90 Deg heat going 80-100mph about 215 Deg.
