Diverdown3
At the risk of sounding uneducated, what does pAO stand for?Keep in mind pAO oils dry out seals and gaskets. High milages variants contain seal swelling group 4/5 esters.
Mine is at the dealership right now getting the phaser cold rattle fix. My service manager said they replace the phasers, chain, and cams. That was a surprise to me since I didn't think the cams were part of the replacement but now it appears they are...Just had mine fixed a few weeks ago. They said they put in the newer design phasers and made sure they noted that on the work order with part numbers. So far, so good after a few weeks. 2019 w 26k when mine went.
That doesn’t make sense. There is no reason to replace cams. Chains are also not necessary and are not included in the TSB.Mine is at the dealership right now getting the phaser cold rattle fix. My service manager said they replace the phasers, chain, and cams. That was a surprise to me since I didn't think the cams were part of the replacement but now it appears they are...
Not replacing the chains and guides while they are in there is stupid. Ford is doing it as cheaply as possible, which is SOP.The plastic timing chain guides, harmonic balancer, rockers, lifters and tensioners are also not included in the TSB, and all are a really good idea to replace
The reason to replace chains is they stretch and it appears techs are not measuring them bc ‘they’re not included in the tsb’
