2017 - 64k miles. No cam phaser work, no valve cover work
looks like I have what is a standard issue, I just wanted to run some details by everyone to see what their thoughts are.
I have oil leaking from the driver side valve cover as well as the HPFP. The leak on the drivers side shows all the same symptoms that people are having with a crack present at the front valve cover bolt
I installed an XDI fuel pump 3k (no leaks present at this time) miles ago. I bought the pump used. It sounds like the bolts securing the pump are a 1 time use (I reused the provided bolts) so I need to buy new bolts and install those.
I installed a catch can 1600 miles ago (no leaks present at this time) and then drove 1600 miles in two trips in a week and noticed the two oil leaks.
I have no codes and the truck runs fine. The oil pressure gauge on the dash shows normal oil pressure
I still need to clean the leaky areas and reverify how bad the leaks are
1) is there any way to screw up the catch can install to cause a leak?
2) how do I QA my catch can install to see if it’s installed incorrectly
3) if my valve covers are not cracked should I replace them?
