Oil Analysis thread (post yours up!)
lathrash
Upland, CA
I got another analysis done. I was planning on doing a 5k mile oil change interval this time, but I had a long trip for work coming up and wasn't sure when the next time I would be able to change it would be, so I changed it early. Nothing exciting in the report... which is good I guess. I'll try to go 5k miles for the next one.
jjeffreyc97
Ponchatoula, Louisiana
Ok, so lets say something alarming comes up in the sample. Is it proof enought for ford to warranty or would something have to fail? Just curious what do you do if something was critical?
Chris@FreedomMotorsports
FRF Gofur
Woodlawn, Virginia
Something would have to fail if I am not mistaken. That is what testing is for, to warn against what may be happening, but when dealing with dealerships there are two things to consider.
First, all dealers are different and some will be great for warranty stuff while others will be be hard to deal with.
Second, a problem arising could be anything, not all problems will immediately point to the source of the issue. Some will, for example, if you have a coolant leak somewhere in the engine for whatever reason, that constitutes a failure that obviously needs diagnosed and fixed immediately. But if you simply have high enough levels of wear material, say iron or copper, it is harder to diagnose the cause for these and most dealerships will not authorize an engine tear down just for one bad oil sample. They will more than likely say to change the oil and test again to start a trend of regular wear before authorizing a tear down.
So it depends on the dealership as well as exactly what issue the sample results show.
DirtNasty
DirtNasty
I need to send this sample out i have had on my desk for a month or two now..
damnit
DirtNasty
DirtNasty
Got my last two oil samples results in today. (amsoil signature series 5w30)
2nd test (first is on the first page).
The last test (3rd)
So far im happy with my Volant+Donaldson air filter and my canton mecca oil filter + amsoil. It seems to be stacking up to be a solid setup (the first test result was using motorcraft oil and a ford filter, that sample set was the 2nd set of oil the motor saw).
