Official Raptor R Modification Thread
BadWRP
FRS 3.2s installed, add phantom w BD lights.
Thanks to Tyson @ Hammer Built Performance, Dave @ Blitzkreig & Billy @ Audiotoys for dialing everything in! Swarfworks V2 3rd brake light incoming.
TheButcher
What are you thoughts on the Race Series shocks on the road? Any changes/improvements?
BadWRP
I’m going to do my best to explain this as best as I can. It’s like putting Kw coilovers on a gt3.
The ride is so much more compliant and controlled. Before over certain bumps and driving, the truck would float around all four corners and sometimes wouldn’t give the most confidence. I always felt the truck was hard to drive it quickly in turns with bumps because it would float around too much for my liking. The ride is slightly stiffer but still comfortable if that makes sense. The truck with collars and forscan adjustment was a stiffer
The new shocks have gotten better and better each day I’ve driven it. The additional rebound and compression adjustment coupled with the increased valving zones really do make it a noticeable difference. The truck itself feels much more planted through turns and bumps. There is also a more of a
Noticeable change in suspension stiffening when going through the drive modes vs stock. Stock I felt a change but it was minimal.
The truck was slightly nose high before with 1.25” collars and now it’s dead level. When installed the shocks we left them at the factory height setting until they break in and make a different decision.
