Nohel's build
Fred
Richmond, VA
X2... Can't believe I have missed the thread either...looks good bud...can't wait to see the final product...
beemerman
Worlds most famous beach
Yes the headers were a challenge. Took me about 8 hours. And I have the lift and all the tools. Have done a lot of headers on various cars. These were definitely a challenge. Especially the header bolts. Not much room. Good luck.
NickPic83
Rockland County NY
i will be doing my install soon. any tips or tricks? anything needed u usually wouldnt think of? will another person or two speed it up some more or is there really only room there for one guy and others just hand him stuff and drink beer
beemerman
a lift is really handy. and if some one has small hands. the manifold bolts are really hard to get at. 1/4 inch drive flexible sockets and extensions help. also gear drive wrenches help also. short and long ones. I removed the nuts off the manifold studs, then removed the studs from the heads, makes it easy to just slide the manifolds out from the bottom. removed the front driveshaft, right motor mount. I even removed the drive belt and dropped the compressor and let it hang to access the front header bolts when installing the headers. also the dipstick tube is a little hard to work around, at the time I did mine the directions were a little sketchy. but I hear the directions are better now. the hard part is the manifolds. the rest of the exhaust is pretty easy. be nice to have help, on mine I used the supplied sealer instead of a conventional gasket. so nice to have help holding the header in place to start the bolts. but the end result is worth it. I did the airraid cia and the 5 start tune from mike. what a difference it makes. I went with the full system the turbo chambered mufflers. and the under the bumper exit. like it a lot. best piece of advice is be patient and have a lot of time. hope this helps. and being stainless, after the snowball run just used some wd40 on a rag and cleans up like new again.
NickPic83
Rockland County NY
thanks! sorry to thread jack nohel but i got one more question for beemerman. what did u torque the header bolts to? how many lbs?
Soldier64
Fort Rucker, AL
^^ My buddy at Ford said 18-24 lbs. I have Headers in the box I'm scared to try to put on... Nohel, great build man! Welcome home, I did the same thing when I got home from Afghanistan but my pallet included the truck. I look forward to seeing the finished product.
96,436
60,366
jinshaohaw
