No exhaust
Cleave
Oxnard, Ca
What is so special about the KO2's?
Sent from my SAMSUNG-SGH-I337 using Tapatalk
The main visual difference is the sidewall treads and they look like they'll have a stronger sidewall than the current all terrain ko, as long as the tread compound doesn't fall apart like the raptor OEM tires they should be great tires
Cleave
Oxnard, Ca
i took my exhaust and have noticed a loss in low end power and if im in traffic idling going below 10 mph on 280 or 101 or anywhere in the bay and sitting for more than an hour without the windows open you can tell some exhaust is coming in. im currently saving for a turn down. only problem is it sounds epic with no pipe and when you put the pedal to the metal which is quite a lot, thats the only thing holding me back.
Hmm, maybe the supercrew cabs are sealed better than the supercabs, I've sat for many hours with the truck running and everything closed and never got the feeling that exhaust was leaking into the truck
locktech
New Jersey
I had the muffler off for a weak when I was waiting for my MagnaFlow to see how it sounded. I couldn't stand the loud drone in the cab. Sounds way better with the cat-back IMO.
