NickPic83's SVT Raptor
Fred
Richmond, VA
I am guessing the LTs will not bolt up directly to my magnaflow without some serious customization?
Whereas if shortys were the route I could bolt those directly to the magnaflow?
NickPic83
NickPic83
Rockland County NY
Shorties will bolt to your factory mid pipe where the cats are. LT's replace the mid pipe and if u order it with factory connect(y pipe) it will bolt right up to any catback u have.
Fred
Richmond, VA
Thanks Nick...so I would need to find a stock pipe since my stock exhaust is among the missing....
So not as much configuration as originally thought with LTs....
NickPic83
NickPic83
Rockland County NY
Huh what's missing. The front end of the Magnaflow should have a flange that bolts to the mid pipe. Thats where the LT headers would end and bolt to the flange.
There is no Fab work they are set to just bolt on.
Chris@FreedomMotorsports
FRF Gofur
Woodlawn, Virginia
Yeah, if you order the LT's with "Factory Connect" then they will bolt right up to your Magnaflow catback, no modding needed. The only reason you would need an extra pipe with shorties (if/when they become available) is because the collectors won't be in the same place as with the LT's, but most companies that offer shorties (I am confident SW would do the same) will also offer a mid pipe for that connection so that they can be bolted directly to a factory connect style catback like the Magnaflow.
