interesting thread on the install of the Volant CAI. I installed one today on my 2013, and it took MUCH longer than I expected, or hoped it would. Had to modify the coolant tank bracket by drilling out the bolt hole that attached to the side wall as it was 5 -10 mm off, and had to 'hammer' the remote start bracket to fit as the provided bracket does not allow space for the OEM part. The fit of the new coolant tank aside the filter box and the other reservoir is too tight, i do not like the fact they all seem under pressure against each other. Also, the top plate of the filter box does not fit properly...there are gaps around the sides. some of the bolts, especially the one for the filter box to the coolant tank bracket and even more so the one in the ram air intake, are miserable to try and access and tighten. I think my chest is bruised from hanging over the front wall to get into position to access them...hahaha. The lack of instructions made it much more difficult than i think it should have been...it would be nice to have more guidance, especially since my truck is a 2013 and the online videos (that show the install in about 1:30 minutes), are representative of older models.
After install, i ran the truck and immediately noticed a more distinguished throttle response, and a much more primal sound when the engine revs. I only ran the truck a short while, mostly watching the temp gauges to make sure the truck did not overheat
. i will provide more updates as i run the truck a bit more...
