![Snoopfacepalm :snoopfacepalm: :snoopfacepalm:](/styles/default/xenforo/smilies/snoopfacepalm.png)
![Beatdeadhorse5 :beatdeadhorse5: :beatdeadhorse5:](/styles/default/xenforo/smilies/beatdeadhorse5.gif)
As much as the, "everything stock is dangerous or sucks", internet warriors hate the KO2s, I'm going to stick with them. Ive not noticed driving on ice dynamics in the rain, the only thing that is disappointing about them is they get loud after 20+K miles. This is pretty much true off all off road tires to some extent, and if it isn't there will be a compromise elsewhere.
the jeep k02 is the best. It actually runs wider and taller than the ford spec.I just had this debate with myself and had decided on toyo's until I found out that SOME KO2's are on a heavy discount from SOME distributors.
Specifically, the part # that comes OEM on the Jeep's
Here is a picture (understand I run a service/tire shop)
The top part number is the OEM for jeeps, the middle one is the generic KO2 (that is load range E). And the bottom # is the OEM for the Raptor.
Everything is the same except the Raptor tire is speed rated for 118 vs 112 for the Jeep. Gen2 raptors are speed limited to 107mph.
Hard to spend an extra 600 (toyos the same as OEM KO2s).
Just passing along the info.
That’s interesting. Is this the rubicon with the 35” package?the jeep k02 is the best. It actually runs wider and taller than the ford spec.
Can't quite make out that part number.I just had this debate with myself and had decided on toyo's until I found out that SOME KO2's are on a heavy discount from SOME distributors.
Correct. I kept the same wheels going from a ford spec k02 to a jeep k02 and I occasionally rub on my rockblockz. Of coarse visually much bigger. Downside is you have a lower speed rating, going from 113mph to just over 100.That’s interesting. Is this the rubicon with the 35” package?
