New suspension components
taquitos
Seattle
Cool ... thanks. So the rear Index components are complimentary with / can be used with taller springs and achieve their intended purpose (factory 35 shock travel)? Same benefits as using with OE (springs)? If so, I’m in.
Yep all complimentary! With lift springs instead of the stock springs with spring spacers, you get the same ride height increase that the stiffer spring provides but with less preload at top out. The spring spacer could actually be stacked on top of the spring for additional lift if someone were to want to do that.
Rob O
PNW
So in my situation, just he eyelets for that 35 v 37 travel benefit?
Appreciate it.
taquitos
Seattle
Appreciate it.
You would want shock eyelets and bump stop spacers. Without the bump stop spacers, the shock bottoms out on the shock body. The shock body can take the force, but best practice is always bottom out on the bump stop itself.
