New suspension components
insangsong78
cali
Next week I will be putting the same on my truck. I received them this past Monday but no time to get them on this week.
I am also changing my wheels from Method 703 to 718. Going from 0MM offset to +25MM. Right now the 703 poke ~ 1.5 inch and i don't like it. I want the wheels a bit more flush
If anyone is interested in buying these let me know. $150 + shipping or if you are in Houston we can meet and process. Not even a year old.
Jealous!!
I have a spare set of shocks and springs ready for these parts!
taquitos
Seattle
Super interested in this kit but trying to find some real world reviews first. Anyone here install this kit yet and have feedback?
I think there’s only one guy on here who has a set of parts if you don’t count me. It’ll be a moment until there are any. The people that have parts now have them because there were a few that were done early. Everything else is getting anodized right now. Actually just about to email them to see if they have any updates on ETA. Hopefully some reviews will start to pop up.
Jr Jr Offroad
Cave Creek, AZ
I’m pretty much dead set on ordering a kit. I was just hoping to find someone who had them with some use/miles under them
taquitos
Seattle
For the time being that would just be me. I know @Carlos M has had parts for a bit but don’t know if there made it on yet. Holidays can be busy after all. Obviously, I'm not third party of course, but for what it's worth...
Installation is easy. I think the one thing people aren't accustomed to doing is the shock eyelet. Once you get enough heat in there to break the loctite, it unthreads easily though. After installation took the truck to get aligned. Toe was only off on one side which makes me think toe was always off on that side. Camber and caster were within spec. So, the alignment really was just adjusting toe on one side.
I really like the added clearance of 37s plus bump stop spacers. Between clearance to the ground being better, especially at full compression, and approach angle being better I think it’s a noted improvement off road. I’d always drag the skid plate and underside of front bumper in one particular area I like to go and it does not drag anymore which is nice. The LCA mounting tabs hang quite low and having 2" more clearance (1" from tire and 1" from lift) is good piece of mind. 35 trucks practically scrap when you bottom them out. I got the 35 truck because I like the go fast off road stuff. Originally Ford was pushing the 35 trucks for that and the 37 trucks for more technical trails, which makes sense. So not losing travel is something I really wanted to achieve. If you look at it from a bottom out resistance perspective, the extra 1” of travel corresponds to the suspension being able to be on average about 7% softer or you could have the same stiffness and on average it would be 7% harder to bottom. I think that’s likely the real reason for 37 trucks to have a different shock tune.
As far as day to day life goes (I daily this truck), I don’t really notice much of an impact. Ride height is taller and the sidewall is more flexible. Those are noticeable when you really throw it into a corner. But it’s an off road truck so I don’t really care. My usual drive is pretty mellow. There's one stretch where I like to hit the limiter every now and then just to do it. Still does that just fine. Have taken maybe a 0.5 mpg hit at most. Averaging 16.2 on that commute. I know it’s not really the point of the truck, but part of day to day. Beyond that, no pops, clunks, thuds, squeaks, or anything. The front is very lightly preloaded and the rear isn't really preloaded at all despite what the spacer might look like (the preload from the spacer is cancelled out by the shock eyelet. I spend a lot of time in the mountains during the winter, so everything is specced to be as corrosion resistant or more corrosion resistant than stock. As such, the parts are still looking fresh right now.
Peppers
Houston
I also have a 21, 35" truck and I am very interested in this kit. Really want to jump onto some 37" Toyo Open Country RTs and this may be the kit for me to finally be able to do that while trying to stay as close as possible to stock and that is incredibly exciting. Following this thread for updates and reviews.
taquitos
Seattle
Production parts are shipping now. Everything is in stock and hopefully won’t run out soon. Prototype parts are fun, but the production stuff looks good. All the parts are compatible with raptors that came stock with 37s too, so if someone wanted a spring spacer or top hat those parts work for that too. The eyelets thread on as well, but 37 trucks already have a bump stop spacer and shock travel is limited by the shock body as well.20-P1040646.jpeg
KustomAF
Riverside, CA
I am also changing my wheels from Method 316 to 318. Going from 0MM offset to +25MM. Right now the 703 poke ~ 1.5 inch and i don't like it. I want the wheels a bit more flush
Any updated pics and feedback with the Index top hats and +25 wheels?
Did you do the whole Index kit or just the front?
