Had my steering rack replaced and I have an issue of the truck pulling to the left. It's not horrible but noticeable. Also driver side wheel rubs against the fender when you turn the wheel fully in either direction. Steering wheel is centered, RPG upper control arms, Rpg front 3.0 suspension and method wheels on stock BFG's. Had it at Ford for a couple of days and they're stumped. Alignment is set to stock factory specs as of now. Any info on how to fix this problem would be great. Thnx.
Alignment 'Within Spec' has lots of pluses and minuses allowed.
Most shops will set up alignment with a minor pull to the left to counter the crown of most roadways.
Check your truck on a level surface (large parking loot)
Look at the lower control arm pivot points; it should be close to equal left and right.
Caster and Camber have the biggest effect on pulling one way or the other.
Camber should be equal left and right.
Caster should also be close to equal with minor variations to counter pulling one way or the other.
If all looks good, check the rear axel alignment.
