Deleted member 12951
Guest
I suggest to have the dealer set it like its set at the factory, with you sitting in teh drivers seat and have the fuel tank full, if they wont let you sit in it add enough weight to simulate you at the wheel and set it to factory specs. Camber/toe is the cause for tire wear and caster causes the vehicle pull. If your caster on left is 4.0 and the right is 3.5 it will pull left. More caster more resistance
Interesting, will have to do that next alignment time. Will probably just buy enough sand bags to equal my weight and put them on the driver side rear seat. Maybe it pulls left because I weigh 325, lol
