New Raptor - Odd Slight Bounce
KingRoman
I would focus on a few things.
Tire and wheel out of balance, get them road force balance to see if the tire or wheel are out of round.
4 wheel Alignment.
Shocks are they leaking or high mileage they could be ready for a rebuild. On my truck this is what was causing a similar issue.
I'll try the road force balance.
The truck has 17k on it, no visible signs of anything wrong with the shocks.
RaptorEnthusiast
So is the so-called "Harmonics" or rolling gallop a normal thing for stock SCREW Raptors? I do notice the rolling gallop going over speed humps in my neighborhood.
Jeff-Ohio
Cincinnati
First, hello all - glad to find the forum.
I just picked up my Raptor this week and I am experiencing something I perceive as a problem, but am unsure.
The suspension feels odd to me, like there is always a slight bounce - very minor, but consistent - like it is not really dampening the road bumps, rather you hit a small road bump and then the suspension oscillates to hit the next and to start all over again - so it always feels like the vehicle is just slightly bouncing as you drive...
This is a very strange sensation and one I have never experienced before.
Any insight would be appreciate - much thanks.
STS
I am by no means an expert since I have never owned a Raptor (mine is being built next week), but I drove a used 2013 SCREW and felt the exact same thing that you are talking about. I was bothered by it enough that I even started a thread on here to see if Fox sells the same shock that comes on the 2017 with adjustment knobs. Per my test drive, I thought the shocks took large bumps fairly well, but they seemed a little stiff on the really small stuff. In addition, I noticed the slight bounce that you talk about. Hopefully the 2017 shocks are more to my liking. If I had it my way, I would adjust the shocks to have a little less compression and bump up the rebound to get them to settle quicker after hitting a bump.
bobcat82nd
Tucson, AZ
If you feel like the suspension is constantly bouncing, have the shock(s) pulled off and checked for the proper PSI and/or potential rebuild. When they need a rebuild or air, the shock does not do a good job at rebound or dampening. The bounce is from the spring doing all of the work.
