@MTF @Truckzor
I eventually plan to supercharge my Raptor. I know one of the recommended supporting mods is billet oil pump gears to replace the weak sintered metal OEM gears. It appears that Melling just released a new High Pressure and Standard Volume oil pump compatible with the Ford 6.2L V8 in the Raptor. The part number is 10397-BR and it should be hitting resellers soon. Based on emails exchanged with Melling product reps, it sounds like this is the perfect oil pump package for boosted 6.2L engines. It comes configured with a bypass spring set to 95 PSI, but includes an alternate spring that drops the bypass pressure down to 85 PSI if desired. Bypass springs are changeable via a hex keyed plug in the pump.
Details:
Melling high performance oil pumps provide dependable performance every time in every application under the toughest RPM conditions. Melling high performance billet rotor oil pumps are standard volume, high pressure oil pumps which feature 130,000 TSI billet steel rotors, a hard coat anodized aluminum body and cast iron phosphate coated cover for improved pump performance and durability. The oil pumps pressure is adjustable by using the optional pressure springs. The oil pump screen mounting seal is included. Every Melling high performance oil pump is individually tested for pressure and flow under actual engine operating conditions. Melling high performance billet rotor oil pumps are recommended for all applications where a high performance oil pump is needed.
UPDATE: @Dane @engine45 Pricing is $540. The product is currently available via Summit Racing and would be drop shipped from Melling. You’ll have to call for now as this isn’t showing up in their online inventory system. Speak to a sales rep.
Details:
