I just PM'ed you. Turns out my headers are Borla longtubes. Apparently there is no way to attach cats to them. I was told I will have to remove them and either go with another brand cats/headers (which is way expensive for me now) or go back to stock manifolds/cats. I was told about 8 hours of labor to remove my current headers so this is expensive any way I look at it...Figures...this is one of the worse case scenarios...
Have you attempted to have the truck inspected yet? If it is not throwing any codes (do you have a check engine light showing?) you might pass.
I am curious about this as well!
I am searching for my first Raptor and found a nice one several states away. About to go get it and read this thread.....
I ask dealer if it has cats and he says it doesn’t.
So if I decide I want this truck, I will need to put cats on it -or- if it is not throwing codes, then will it pass emissions?
I am in cali and have the same problem. The5 star tuner eliminates the check engine light but if you hook up a scanner tool you can see the incomplete codes. The smog shop can not pass as it reads the incomplete codes same as the scanning tool. I am not sure what to do next, have magna flow aftermarket cats installed but what to do with the incomplete 02 sensor codes. Need help in Commiefornia.
I purchased the truck from Texas. Kooks headers and magna flow exhaust and no cats. It is also way over the 95 decible rule as well.
