Do you have any photos of the standoffs?By the way, just to reiterate, I have the tailgate step, and the 60" Putco Red Blade. You can mount the blade either flush mount or with some small standoffs which are included. The standoffs make the blade clear those screws on the sides that the tailgate step trucks have.
This is the Putco page. https://www.putco.com/blade-led-tailgate-light-bar It has a bunch of pics you can scroll through and see what is included with the blade. Keep in mind there are two ways to mount the blade, directly or with the clips. Included are some 3M adhesive strips, which you could use to mount the blade flush directly to the sheetmetal, and in which case the tailgate step bolt heads would be a problem, and you would need to get a shorter blade. There are also some plastic clips included, whereby you can mount the clips flush to the sheetmetal, and then the blade goes into the clips, and given the little bit of clearance provided by the adhesive and clips and flexibility of the blade, it can clear the bolt heads.Do you have any photos of the standoffs?
Thx
It’s plenty of light for reverse. If you have the tail gate step the 60 “ will not fit due to the bracket and you have to go 48” . I did not wire if for stop or turns , just wanted the reverse light
It looks like this is the light bar that he is runningIt’s plenty of light for reverse. If you have the tail gate step the 60 “ will not fit due to the bracket and you have to go 48” . I did not wire if for stop or turns , just wanted the reverse light
