Hello fellow forum members,
I'm having some issues with my 2018 Ford Raptor Gen 2 and I could really use your help. The problem is related to the Terrain Management System Fault. So far, I've checked the fuses, reset the modules, and performed a visual inspection of the front shock absorbers. Unfortunately, I haven't been able to pinpoint the cause of the problem.
During my visual inspection, I couldn't find any solenoids on the FOX Racing shock absorbers. All the cables seem to go directly to the ball joint and appear to be related to the speed sensor and ABS system. Additionally, I haven't been able to locate the VDM module in FORScan, the fuse 14 is in place and no shortcut find it.
If any of you have experience with the Gen 2 Raptor, I would really appreciate your assistance in verifying whether the VDM module is available for the 2018 model. Any ideas or suggestions would be greatly welcomed, as I'm at a loss for what to do next.
Thank you in advance for your help!
