my tough issues
M
Mil T
Payson, Az
Nice write up, When you had this issue, you didn't happen to get a message for your Rear Camera not receiving the signal on the Nav System? I get this message every once in a while and then it will fix itself.
No but I had lots of very strange things going on at different times. That doesn't mean that yours isn't a problem with the wiring loom being pinched. The loom has many wires in it and on my situation the mechanic found that the sharp piece of metal had a small sharp wire *** on it that penetrated the loom and only one wire. You actually had to look very hard to see the hole. You could have one or more wires being pinched. The simple way to find out if it is the wiring loom is to just raise the seat up. You can see by the pictures that once you raise the seat that the loom cannot be pinced.
