My Ford Touch Update to v.3.6
MTF
MTF
Celebration, Florida
All depends, one or two upgrades? Depending on if you have MFT equipped on you truck.
You'll need to go to your Ford Owners website and run a check
bucktown
I'm assuming you had the truck running the whole time?
Did get the success screen?
Yes, the truck was running and yes I got the success screen, I followed the instructions to the letter. When I check the version installed, it says the correct one.
Same thing happened to mine.
Turn the truck off, pull our USB drive out. Pull out key. Open drives side door. Close drives side door. Insert USB drive into slot. Turn truck on.
There ya go.
Sent from my iPhone using Forum Runner
I will give this a try in the morning, can I ask how you came to this solution??? Thanks for the tip!
edit: unfortunately this didnt work for me. I have an appointment in a couple days, anyone have any other suggestions?
bucktown
Ended up going to the dealer. They reinstalled the software and everything appears to be working as it should.
skyl3r
Maniac
FRF Lady
East Texas
all I can think of is
