My DIY rear bumper project
Fb73
Fb73
France
Did you remove the fuel tank? How does that work? Nice job on the bumper.
No the LPG system is an "Add on" system over the stock fuel system. Basically the truck always starts on gasoline so the engine can heat up, the LPG system is using the cooling circuit to get the gaz on the right temperature so it doesn't freeze in the lines & pressure relief valve...When the correct temp is reached, system automatically switch on LPS and vice versa, and you really don't notice anything....The LPG system has its own Keihin injectors, PCM etc...Gasoline is pretty expensive here so LPG allows me to save a lot of money on fuel consumption, money I can spend on truck parts !! :biggrin:
