Idleone
Did you get a verdict from the dealership yet, Idleone? What's your truck's model year/mileage?
Crystal
I just dropped it off this morning. Its a 2011 Screw with 40k. I will get back online later and update.
Crystal
Next time it happens take that smart phone & record it & show them the evidence & tell them to replace the head unit. I believe you said you have already replaced the blow motor resistor, so it's probably the head unit. Good Luck!
That sounds like the blower resistor. It's an easy swap. It's in the glove compartment. Two screws, one cable plug. Let me see what part number I ordered.
---------- Post added at 07:54 PM ---------- Previous post was at 07:52 PM ----------
This is what I got from Tasca.
You do have ATC, You need P/N BL3Z-19E624-A $37.17 and in stock. http://www.tascaparts.com/oe-ford/bl3z19e624a?search_str=BL3Z19E624A
I swapped it but unfortunately it did not solve my problem. But that one where the two speeds don't work could be this.
Thanks for that info brother. Couldn't tell from the site but I wonder if it's the same part across model years ?
So my problem seems to be resolved. They replaced the blower motor speed control part #BL3Z*19E624*A. I hope this does the trick. 98.00 out the door.
