Motorcraft Super Duty Brake Pads?
T
Truckzor
Update: I now have these pads. To me, they seem like a pretty solid improvement over stock. Pedal feels firmer and they definitely have a bit more bite. They do seem to chatter a bit at very low speeds like when you are just starting to get rolling or when you are coming to a stop. I'm happy with them.
Humvee21
What's the part number for the rears? 2 Amazon reviews for BRSD-1012-A say it doesn't fit 2012/13 F150's.
Humvee21
So I ordered and attempted to install the BRSD-1012-A on my rear brakes over the weekend. They did not fit my 2012. I am guessing there was a design change for the 2013/2014 models?
The BRSD-1414 fit my front brakes just fine.
Chris@FreedomMotorsports
FRF Gofur
Woodlawn, Virginia
Chris thanks for the info. That's a little strange considering they fit on Truckzor's 2013 but not my 2012. I have no idea...
It IS possible that you have an EARLY 2012 model. What is the build date on the label inside the driver door jam? If it is early enough, like mid 2011 or something like that then that would explain it.
Humvee21
Mine was built 12/2012. I was curious about this so I dug a little deeper this morning. It seems that Truckzor's 2013 might have the 2010/2011 brakes. The reason I say this is because I searched on Fordparts.com and Rockauto and the BRSD-1012-A fits 2010/2011 trucks but does not show compatible for my 2012.
I attached some pics of what the rear pads actually look like.
FRF Gofur
Woodlawn, Virginia
While not common, it is possible. I have seen stranger things happen.
