Morimoto Announces NEW 2nd Gen XB Headlights for Gen2 Raptors
Tmeier299
We just opened our set also, same thing. Seems Morimoto forgot to include the OEM Harnesses in all of the kits they recently sent out. We just emailed them asking what's going on. I know Morimoto switched to a new shipping platform so now they no longer hold shipments if part of the order is out of stock. They just split it automatically. So there is a chance that they shipped the lights and will ship the harnesses when they are in stock. BUT, it would have been nice if us dealers got a heads up right?
Anyway I put an email into them and i'll let you know what they say. I'll respond on here as well as your direct email since all of the Morimoto dealers are experiencing the same issue with the missing OEM LED Harness.
Can you make sure I get the proper harness for the Bugatti options as well. The one DetTigers mentioned
DetTigers
Michigan
Without the DRL harness neither light worked for the Bugatti startup sequence. After I hooked up the DRL harness only the passenger side works for the Bugatti startup. The lights seem to function fine other than that but I won’t be completely happy until both lights function as they should.
Ducc
Arizona
Good to finally see these in action, but bummed you guys are experiencing problems. Looking forward to future updates.
4x4TruckLEDs.com
4x4TruckLEDs.com
You need to make sure you remove the drivers off the lights, as they are only used with the Halogen setup.
4x4TruckLEDs.com
4x4TruckLEDs.com
I'm not 100% certain you need that. The DRL harnesses are always included as the non-OEM LED trucks need it. But with OEM LED you never use the included harnesses. The 2nd Generation lights are new, so we need to ask if you DO need them. But with the OEM LED setups, you don't wire in the drivers on the back/bottom of the lights, you bypass them (i usually remove them entirely). Those are only needed for halogen equipped trucks, which is why Det might be having issues.
DetTigers
Michigan
The guys at TRS told me that the Bugatti startup sequence requires the DRL harness because of the power it draws. I tried the lights without the harness and indeed, neither light had the startup sequence. With the DRL harness installed the passenger side works. I tried 4x4LED’s suggestion and removed the driver side DRL connection but it didn’t fix the problem.
DetTigers
Michigan
Ok I misunderstood you then. I disconnected the DRL harness from the driver side. What black drivers are you talking about?
4x4TruckLEDs.com
4x4TruckLEDs.com
Det. who did you buy from? The dealer you bought from should be assisting you. I don't mind helping you out but it's best if you just email me, [email protected] instead
