Morimoto Announces NEW 2nd Gen XB Headlights for Gen2 Raptors
DetTigers
Michigan
No worries. Regardless of where the lights are purchased from everyone is going to be troubleshooting these issues. If/when I find the solution it will benefit everyone who purchased them. As of right now no vendor has the answer. I’m sure Morimoto will get it figured out.
4x4TruckLEDs.com
4x4TruckLEDs.com
Well it might not be a Morimoto issue but an installation problem. It's best to contact the dealer you purchased from directly to work out your specific issues (or as I said, email me at [email protected] so I can help you out).
DetTigers
Michigan
Ok fellas- good news is my lights are now working perfectly. Bad news is I’m an idiot. I had the driver side DRL harness hooked into the wrong plug. There are 2 identical looking plugs, the one with the blue wire is the correct one.
So bottom line is once you get the LED harness and proper DRL harness with a mini fuse tap you will be good to go.
Tmeier299
Great Thanks for letting us know.
Tmeier299
Can you make sure I get the proper harness for the Bugatti options as well. The one DetTigers mentioned
I'm not 100% certain you need that. The DRL harnesses are always included as the non-OEM LED trucks need it. But with OEM LED you never use the included harnesses. The 2nd Generation lights are new, so we need to ask if you DO need them. But with the OEM LED setups, you don't wire in the drivers on the back/bottom of the lights, you bypass them (i usually remove them entirely). Those are only needed for halogen equipped trucks, which is why Det might be having issues.
Can you make sure I get the DRL harness with the mini fuse just like DetTigers description
Ducc
Arizona
You mind posting another video with them working properly? That would be huge. I'm on the fence with the morimoto's right now.
