Morimoto Announces NEW 2nd Gen XB Headlights for Gen2 Raptors
4x4TruckLEDs.com
4x4TruckLEDs.com
No we recently changed our site today to mimic Morimotos. Prior to today we threw it in at no charge
Nood1es
Madison, WI
Got these installed today. If you’re on the fence. Get them! Order it from adam, fast shipment and super helpful.
ps how much do used ones go for?
mattl600
Los Angeles
Got the "Bugatti Sequence" and DRL line hooked up. Here is what I did - and what works on my truck. Bought Micro 2 adapter from NAPA, bought 7.5A micro 2 fuse, put in top slot (to lights).
Fuse 14 on the Raptor is a spare 15A, always powered slot (doesnt require ignition, same as headlight power). Pulled the spare 15A fuse and placed in bottom of Micro 2 adapter. Plugged adapter in.
Lights cycle bugatti sequence on ignition only. DRL's are "always on" as intended, even if I disable in dash options. I have the forscan hack on, so if I run with DRL's enabled, it looks exactly as it did prior to the add a fuse wiring.
Nice..
I moved from the manuals recommended fuse location to fuse 14 and no longer have the lingering DRLs that stay on for minutes after the car is locked and turned off.
Bugatti sequence still works as well.
Thanks!
nikhsub1
Los Angeles
So for those that have installed - is it easy to install the drl harness AFTER the lights are installed or better to do at same time? Reason I ask is I think my drl wire is delayed but the lights are coming sometime today. TIA.
4x4TruckLEDs.com
4x4TruckLEDs.com
Check your box. Was there a DRL harness in the box (usually they ship with a MINI fuse tap DRL harness).
If so, you can install the MINI Fuse Tap DRL harness, and then when your MICRO Fuse Tap DRL harness comes in, just cut off the mini fuse tap on the existing harness, and splice on the Micro fuse tap. That's actually what I did on my truck. I installed everything and left the wire by my fuse panel and did it another day.
nikhsub1
Los Angeles
Ok so then run the wire at install then, splice micro tap later. It's weird, got 2 ship notifications from TRS, one for 1 lb which is delayed (assuming this is proper fuse tap wire) and then the 37lbs which I guess are the lights, coming today.
rayofsi
NYC
they did that for me too, the 1lb one was eventually voided. my harness was in the box with the lights
4x4TruckLEDs.com
4x4TruckLEDs.com
The XB Headlights ship with a MINI fuse tap, as they use this on the non-Raptor 2015-2017 trucks. The 2017-2020 Raptors use a MICRO fuse tap however, so it ships separate. They are not going to spend time to open up each box to find the mini fuse and then re-package everything. Easier for them to just ship the micro fuse tap separate.
You said you got a notification from TRS? You didn't order from us???
nikhsub1
Los Angeles
I did order from you.
