- Joined
- Jul 18, 2017
- Posts
- 2,978
- Reaction score
- 1,392
Longest i've seen is about 5 minutes I think.
Maybe this has been answered but - For the DRLs to work to you need to run the DRL wire to the fusebox? Or is that only if you want the startup animation?
Its for both the amber DRL and the startup sequence.
Hi, to anyone who has installed these lights, is it hard to adjust the high beams? Do the high beams have to be adjusted prior to bolting the lights back into place? Also I understand there's one dial to adjust all low beams at once but do the low beams have to be adjusted left and right also, or is the horizontal position fixed? I think the original morimoto's for the gen 2 raptor had a left and right adjustment dial? Been looking over all 33 pages of info on these lights and getting ready to buy them. Thanks very much in advance!
For me it was just the 8mm bolt up top to raise the level of the low beams.
I didn’t see anything for horizontal adjustment but to be honest these go so wide I couldn’t imagine needing it.
just the single bolt on top adjusts low and high beams, since the highbeams are now bi-led on the v2?Thanks very much for the info!
