This looks good. I have an extra onx6 10 inch laying around not being used. I wonder if i could just get one more run two of those on this. Have not touched the front end yet my 24 with the new bumper.
Can I ask how you what harness you used and how you configured them? I’ve got 4 LP9s mounted, but I’m waiting for a custom harness. I’m dead set on wiring them to my high beam as a trigger. I hate cruising back roads with my hand hovering below the up fitter switch on my other truck. Thanks!
I would use LVJ motorsports. You can call him and he can set you up however you like and It looks like you’ll get the same harness as me just the basic harness for 2 inner and 2 outer lights with backlight. He doesn’t recommend using low sweettijf but if you have a switchpro it will dim them for you . He will label the wires for you too so you’ll know how to set them up. He will know how to do that also what you’re looking forCan I ask how you what harness you used and how you configured them? I’ve got 4 LP9s mounted, but I’m waiting for a custom harness. I’m dead set on wiring them to my high beam as a trigger. I hate cruising back roads with my hand hovering below the up fitter switch on my other truck. Thanks!
That LVJ harness looks solid.I would use LVJ motorsports. You can call him and he can set you up however you like and It looks like you’ll get the same harness as me just the basic harness for 2 inner and 2 outer lights with backlight. He doesn’t recommend using low sweettijf but if you have a switchpro it will dim them for you . He will label the wires for you too so you’ll know how to set them up. He will know how to do that also what you’re looking for
LP6 / LP 9 Custom Wire Harness | lvj-motorsports
Custom made wire harness for Baja Designs LP9 and LP6 with 4 pin Deutsch Connectors, Harness is custom made for up to 5 lights and can be wired to turn on outboard lights seperate from inboard lights so you can have just the ambers on or just the white lights on. Harness includes 3 circuits...www.lvjmotorsports.com
Yeah I think you’ll just need the basic without any relaysThanks. That’s who I’m waiting on for a quote.
Have you looked into resin printing for that console adapter/mount? Would give that oem finish vs the layer lines of FDM printed parts. Couldn't help but say something since I print a lot of stuff hah.I made harnesses for my 9s and S8. Wired to a Switch-Pro. I would advise not using the high beam as a trigger. It has been known to mess up the BCM.
