Metal oil pan and drain plug?
HAZMAT221
NJ
I’ve read on some threads that the turbos on later models 18+ have more compression on the turbos. Don’t recall exact threads beacause I was lurking on here for a while before making an account.
I suppose I just want to know if there’s anything should watch for on having an engine designed for a later model on a 17.
O
OriginalToken
The only Turbo changes I can think of already apply to all Raptors, from the first Gen 2 on.
As for a later motor in a 17, there should be no issues. In fact, if there is anything to the Phaser issue with earlier motors you may be past that with your new long block, having those improved parts in it.
In general I can't think of anything you particularly need to be watching for.
T!
HAZMAT221
NJ
T!
Hope that’s the case! Thanks for the input
Raptor911
Ashburn, VA
Could you ping me your vin? I want to pull the car fax and see this for myself. If the engine was replaced under warranty then it should have not appeared in the carfax.
Car fax indicates the “Long Block was replaced” around 21,000 miles. Could that be the reason? Did a google search but that didn’t indicate anything specific for the raptor.
