Make that 4.92 seconds.
NASSTY
ME
so much not good info being swapped around about 4h..... the anxiety, it kills.
that dodge was from not understanding how dragstrips work. he wasnt in 4wd.
you will cause premature wear and potential failure on your components using them on dry situations. lots of binding and super hard to turn, but unless you are actively trying to explode something it wont explode like that. that being said, dont use 4h on dry pavement.
Running in 4hi on pavement doesn't hurt anything as long as you don't make any turns. I've never seen a drag strip with turns.
shunderwunder
Baja mode locks to 4H...can't be changed.
edit. Just remembered it was 2H that is selectable not 4A like it was thinking.
---------- Post added at 07:00 PM ---------- Previous post was at 06:52 PM ----------
Nice numbers! The accuracy of the device isn't that important as long as its consistent and you can see the difference from upgrades. Its more about seeing a gain than it is about knowing the exact time.
GizmoVance
Yes, correct. My point was...that you cannot use 4A in the Baja mode.
TMW!
Can that Raxiom read Engine Oil Temp or PSI?
Bullishone
Bullishone
You guys are more concerned with everything the raptor was NOT built to do.
Like going fast?
Like outperforming every truck on and off the road?
Like modifying it to make it even faster and better than any truck on the road?
Like daily driving it because I want to?
Like personalizing it the way I want?
Like driving it through the Canadian Rockies every winter from Seattle to Calgary and back?
pjones
Have you tried wearing a wig in your Grindr profile?
Sent from my Nexus 6P using Tapatalk
Yes, he did. Still no love.
---------- Post added at 02:21 AM ---------- Previous post was at 02:20 AM ----------
You are more concerned with a truck you will never own.
